What did you do to your non-G body project today
Wageslave
Wageslave
1,130
Got some work done on my long forgotten garden tractor project. It's an 84' John Deere 214. I rebuilt the Kohler K321 14 HP engine ten years ago or so but never started it, just rolled it over from time to time. I picked up a non running JD LT133 this past winter and got that all straightened out and am pretty pleased with it. So with a little head of steam I pulled this tractor out of the corner and started tinkering. The fuel pump was shot from sitting for years with a thimble of fuel left in it so that's ordered as is a carb kit just to cover the bases.
While waiting for parts I got to work on the seat pan, it was pretty rusty but garage kept for the last 13 years so it didn't get any worse. I'm no Donovan and won't BS you, it's an improvement but it's not going to be a beauty queen, a 15'er at best. I got 4 coats of JD primer on it out in the sunny backyard and it dried as quick as I could spray it. Plan to d/a it with 220 and try to smooth it out some, then put down two or three more coats of primer to build it up a bit. I'll lightly finish sand with 220 and spray it with JD "Classic" green next week while on vacation. I like the Classic green more than regular JD Green that it should be painted, just my preference.
View attachment 146730 View attachment 146731 View attachment 146733
Painting a John Deere yellow. That would get you stabbed by the tractor purists around here.
Wageslave
Wageslave
1,130
You're not far off.
Pc3
Pc3
286
Brought the ole girl home yesterday after being away for just shy of a year.
This morning I set out to get her fired up. 1st thing on the agenda was to change and filter the used oil and cut the filter for inspection evething looked good.
I pulled the valve cover And a smile came to my face
Super clean Ok ok I had slight movement in the pants.
Set out to change fuel filter and dump 5 gal of sunoco 94 and a 1/2 can of 104 octane booster. She was bone dry not a drop in the tank or fuel filter. Well
Things didn't go so smooth from there. As I moved towards the front of the car to connect jumper cables and battery charger I started getting a strong order of fuel. Yep the braided line was dry rotted and leaking.
Took care of that. By switching the feed line from the pump to carb.. To the rear filter.
Lucky for me I am a hoarder and don't throw much automotive parts out., dug thru my AN fitting stash and made up a new line for the carb.
So a couple of hours go by and I am ready to fire her up...go hit the ignition key and nothing. NADA I am like what the fudge!.
I scratching my head
I have power at the ignition. Power at the coil fuel in carb .
Screw it
tomorrow is another day
motorheadmike
motorheadmike
5,102
Ottawa, Ontario Canada
Decided to address the roughly 4 year-old problems with one of the TBSS' HVAC actuator motors which broke on Drag Week, and it has been unplugged ever since. Tried doing a reset, which was fruitless. So I got to pulling it all apart: https://www.trailblazerssforum.com/forum/viewtopic.php?t=8
Once I had the actuator apart, and found a tooth broken off the main gear I gave the whole thing a once over. It only uses about 30* of the gear for the swing and has physical stops - but the gear isn't indexed. So I popped it off the main shaft and spun it around 180* and slammed it back together. Re&Re-ing these actuators is a horrible job to do. But... No more clunky noise, air out the main vents, and no money spent.
I did happen to get eaten alive by a horde of mosquitoes, and probably a sunburn too. Still trying to understand why I did it in the driveway versus in the comfort of my garage?
When I got that finished I completed my mission to make the best ribs ever.
24 hrs marinating in Dr. Pepper then broiled. 4 more litres of Dr. Pepper reduced to a caramelized syrup to make the BBQ sauce. Quadruple glazed on the BBQ. Meat sweats inbound.
The McRib can eat a McDick.
motorheadmike
motorheadmike
5,102
Dr Pepper ribs, eh? Never heard of that one. Any dry rub?
I usually dust mine in Old Bay, throw a Miller Lite in the bottom, roast in a pan on a rack covered with foil on 225-250 for 2.5-3hrs, then finish on the grill with Sweet Baby Ray's. They pretty good 👍
Yes, we have a special dry rub we put on before it hits the grill (paprika, salt, black pepper, onion powder, and cayenne pepper). I've done ribs in beer, Coke, various root beers, and Dr. Pepper. The pops have a fair amount of acid and sugar in them which breaks the meat down a bit and pulls the sugars into it over night (at least that's the theory). The really interesting thing is when you broil the ribs in the pop all the colour leaves it - which is kinda wild considering when you reduce the pop in a sauce pan it goes blacker than the Grinch's heart.
Chemistry, b*tch!
Hmmm... I need to make a beer can chicken again.
motorheadmike
motorheadmike
5,102
Alright, I'm calling shenanigans. There's no way you're an officer in the military. You don't conduct yourself like you have a giant stick wedged up your *ss.
Don't @ss-u-me what is or isn't up my butt - stay the hell outta my bedroom!
Clutch
Clutch
4,352
Brick NJ
So today I was going to do a quick brake job on the new truck and then change the lower ball joints. Yup no! I got to the shop nosed it in and realized I forgot the ball joint press in the back of the suburban at home. It was already pulled in so I went ahead and did the front brakes new cross drilled and slotted rotors with semi-metallic pads no problem except ba little rust but that's to be expected. Then I spun it around and started in on the back. I don't think the rear rotors had ever been off. It's a good thing I was at work air chisel and bfh! Did the right rear first. Took the left rear apart and one piston in caliper would not collapse. Called the wife had her go to a parts store and get me a left caliper and brake fluid also had her bring me Lauren to bleed the brakes. All good NOT driving home I smell brakes burning. The left front caliber went bad oh well I just ordered that stuff and
And a new rubber line. All good though NJ DMV won't be open until June now KIMG0237.JPG
Thread starter Similar threads Forum Replies Date
69hurstolds Had planned on new truck tires. I did end up getting some, but got more than I intended. General Discussion 12
Streetbu What did you do at work today? OFF TOPIC 65
S What did these come out of? General Discussion 5
Bar50 What did you do in your shop or to your car today during the pandemic? General Discussion 14
gnvair Did any of you see the 79 5 speed set up for sale? Oldsmobile Cutlass / 442 / Hurst/Olds 16
69hurstolds How did you get started with your G-body obsession/restoration? Here's mine. Show me yours. General Discussion 31
pontiacgp What Did You Do To Your G-Body Today? [2020] General Discussion 1339
blk7gxn Did you receive any G Body parts/Items for Christmas!!!?? General Discussion 15
M Did reunite with a teacher of mine OFF TOPIC 0
Bonnewagon How did it know?!? General Discussion 25
M Did get through a niece of mine OFF TOPIC 0
RecklessRegal What did you do to your shop today? General Discussion 266
565bbchevy What did this SBC power steering/ alternator combo bracket come off. General Discussion 1
Dktalee Help finding a HEI non CC Distributor General Discussion 3
8 Passenger side non ECM kick panel G-Body Parts For Sale / Trade 0
S Back Glass: 1978 Malibu A-Body Coupe (Non-Landau, Non-Vinyl Top) Body / Trim / Paint / Glass 2
08Malibu 79 t top vs non t top b pillar difference Oldsmobile Cutlass / 442 / Hurst/Olds 0
Red78Calais4speed Non-tilt manual trans steering column G-Body Parts For Sale / Trade 6
C Its official - first non-sports car Mustang OFF TOPIC 69
C non ac control head Cooling / Heating / AC 9
M AC to non-AC v belts Cooling / Heating / AC 2
GP403 GEAR 2021 G-Body Calendar General Discussion 0
techg8 Help please, one 2004r valve body Roll pin (large) needed Wanted 0
M G-Body of the Month G-Body of the Month 1
jakes87SS just picked up the july 85 car and driver G body issue General Discussion 12
M G body AC compressor cycling question Cooling / Heating / AC 9
8 How To- Mounting W body buckets in a G body Interior 5
P Need help decoding a 1981 Malibu body tag General Discussion 1
mlarcey iroc hood on g body General Discussion 16
D Will these new Ridler wheels fit a g body? Wheels / Tires / Brakes 6
S Olds 455 G Body Headers New Users 4
M New member, longtime g-body fan New Users 6
7 New Pearl Jam Video has a later model G body Cutlass at the beginning... Photos, Videos, etc. 4
kornball426 GTI brakes on G body General Discussion 3
602gbody REGAL phx g body New Users 4
Olds G's 1988 Cadillac Brougham D Body Forum Non-G Projects 3
Bonnewagon 15" x 6" or 7" Rally II's on a G-body? Wheels / Tires / Brakes 20
J F body donor car General Discussion 89
C CHEVY New life to an old square body farm truck Non-G Projects 13
gnvair FOR SALE Serpentine belt a/c hoses for 88-92 F body G-Body Parts For Sale / Trade 7
69hurstolds HJ prototype Label for G-body- Guess where it goes! General Discussion 14
MrSony Body Mount Trunk Cage Nut Repair Panels? Frame / Chassis / Suspension / Steering 6
gnvair Are the 82-02 F body rear lower controls the same as the 78-88 A/G bodies? Frame / Chassis / Suspension / Steering 2
Rktpwrd Body Guys - Clearcoat recommendations Body / Trim / Paint / Glass 44
Texas79cutty Another g body G-Body LS Swap 0
81_El_Homewrecker B-Body Master only Wheels / Tires / Brakes 15
80malibudriver Tremec TR3650 in a g body Manual Transmission / Clutch / Shifter 11
vpmac Are these G Body seats G-Body Parts For Sale / Trade 3
N Body parts comparison Body / Trim / Paint / Glass 3
MrSony Best, most complete body bushing kit? General Discussion 11
Similar threads
