What did you do to your non-G body project today? [2021]
88hurstolds
1,747
652
Did an oil change and even thought about installing an NOS hose until I discovered a few fouled plugs on one side checking things over...
Now gave to pull the intake and reseal, pulling oil from the lifter valley.
6,793
6,678
Tried and failed to diagnose a weird massive stumble my truck has. It will quite literally studder, stop for about 5 seconds, stutter, stop, and repeat if I give it any more than half throttle. Elevation changes makes it worse. Up, down, sudden acceleration, hates it.
Plugs look like this. Never had a plug look like this before. What's the deal? Is it running lean and burning oil at the same time? The stuff is burnt on good. Had to chip it off with my nail.
It's a 45 year old truck so weird things are to be expected but even the old plugs weren't this bad.
CopperNick
3,347
3,011
Canada
HEY! Gimme a break here. Just rolled out of the rack and haven't even had brekkie yet, never mind wandered out to the shop.
Did manage yesterday to finally finish cutting and lifting all the sod I needed to remove to gain the room I want to create a larger patio/paver stone outside work area in front of the garden garage doors. Next step is to acquire the pavers themselves and lay them in.
Before that can happen I have to finish my "other" project, that wheeler/dolly that I commented about earlier. Have all the sections of tube cut and scored some weld ells so the next step is to fit the tube and clean it up to accept being tacked and then fit it all together. Most of the joints are going to either get bushings or sleeves of the same material and thickness as the tube to increase the overall thickness at the weld joints for strength. This is a both a safety issue and a way to avoid burn through, the tube is only .060 wall whereas the fittings are .140 or heavier. The heat that the ells can soak up is a lot greater than what the tube will take, so making the tube "thicker" by adding a sleeve or bushing gives me an end run around the issue. Once I cut and fit the bushings, the outer tube gets drilled so that I can plug weld the inner material to the outer. Not gonna move, nevah again, no mo. Oh yeah, pictures...…………………(Sound of crickets and snoring) yeah, yeah, probably when I get enough of it tacked together so anyone taking a peek gets the general idea here.
No movement on the cribbing. I need the exterior work space to set up a production line to cut the wood for the rails and stiles. Problem is that the local Weatherheads just keep sniveling about snow and rain and cold and BLEAH!!! Ever time a dose of that sh** gets dumped on my parade it takes a day or two for the ground to thaw and then dry out so no interval between sh*t one and s!it two; it just keeps coming. Did manage to get the shop warm enough to turn off the heat for the season. see what that does to the gas bill. No plans to make the cuts in the shop; sawdust and welding sparks do NOT get along and I would purely hate to have to explain to the fire investigators and the insurance mooks that I was the author of my own misfortune here. They have no sense of humour; think it got stolen by a scanner.
6,793
6,678
fresh plugs and truck runs as it did. I also had a hell o f a time replacing the three passenger side freeze plugs as they had all rotted through.
Starter off, motor mounts off, raise engine, pop plug out, get water everywhere, scoop out rusty sh*t, scream for 3 hours trying to get one plug in, decide to do the other 2 on that side, then reverse process. no leaks yet. knock on wood.
scoti
1,959
3,365
Texas
Cleaned up the grunge & old paint on the Model-A motor. It still had overspray on the back of the block from it's partial restoration sometime in the late 50's. It's crazy how good of shape everything is on this little buggy. This car basically had <3k miles after being rebuilt @ that time w/most of those miles accumulated in recent years doing some Model-A club 'Texas Tours'. Plan is just to clean-up things (had a questionable/leaking head gasket), swap on a higher compression (later model) 'B' head & cam combo, & period correct appearing electronic ignition. We're also swapping rear end set-ups for some milder gears to help rpms on a budget. My buddy spent the coin for a 4spd set-up (3spd w/OD) for his car & it has 3.54's. My car has the OG 3spd/3.78 combo. We'll be swapping things between the two so his doesn't lug & mine will fair a little better on the highway. Mine will be getting different wheel/tires (shorter) so the milder gears really will help the rpm's.
Once it's moving under it's own power, I'll re-focus on the altitude & rolling stock along w/full fluids & brake servicing. Learning a lot about these little cars!
81cutlass
4,639
13,542
Western MN
Why would you fly, it's only a 2500 mile round trip!
Drove the 40 hour round trip to the FL panhandle and did some lounging last week. Saw some sand, a big boat, some blue planes and a cave.
Never been to Arkansas, Alabama, or Mississippi so knocked those off the list.
7,981
18,676
