What did you do to your non-G body project today? [2022]
6,012
12,717
I've actually got my eye on another.... but he's a bit too high on price for me. It's a Troy bilt super bronco with everything good except a rusted out deck..... and I have a good deck with anti-scalp wheels from the tb42 that would fit.
He wanted $200, got him down to $160 so far, but really only wanted to pay $125. That one would be a 10 minute fix....
It's a good side gig and occasionally you find a machine that you like enough to keep around for a while, cut the grass or pick up the leaves with. Do it long enough and you'll start to develop favorite models and brands to work on and flip.
ck80
5,743
9,121
So far I really like the old gear drive pony, simple to work on and all.
Wife already asked me if i put this one back together would I keep it and she could use it in hlthe yard.
BUT.
I do find myself getting into it nand doing all kinds of reading TRYING to learn, although I'm still a newb.... weird, I have an addictive personality for activities but not for substances. Go figure.
Guess this makes me Lord Vader to your Palpatine. Watch out world, I'm discovering the power of the Dark Side
Nice thing is unlike my cars or trucks, I should be able to work on and next to them in my limited state without much assistance and it'll let me be constructive.
Ugly1
1,636
1,369
Lost in the woods of NH
The camping boiler sounds interesting, given that the first aussie video used wood as the fuel. Thing here is that both of them will probably howl like dogs on fire once they get up to operational RPM. That Aussie got his turbo so hot it had turned bright orange/red like the flame on a brazing torch. So. both noise and fire violations for the CO's to cite you for.
When you don’t have neighbors to worry about it, anything can happen
Ugly1
1,636
1,369
+1. They used to be a common accessory that you could buy from any Car parts shop. Think they even were listed in the old version JC Whitney catalogue. Seem to recall that my dad had them put on one of his cars; not sure if it was the old Buick or the 63 Impala.
They were made of rubber with copper stripping embedded in it. The copper was exposed and the strap was long enough that it dragged along behind the car. The attachment was just a sort of screw clamp; absolute KISS principle at play so even someone totally devoid of mechanical skills could attach them to the lower bumper flange using a pair of cheap slip lock pliers from the kitchen catch-all drawer.
The why of them was an era belief that cars could generate and accumulate static electricity and that if they weren't properly grounded the static could damage the electrical systems. Any of you recall wearing pants as kids and feeling that snap of static when you slid either into the family car or out of it?? HEY!
Don't look at me in that tone of voice, This was the Eisenhower era and Eisenhower thinking at its finest here.)
Wasn’t it also for filling the gas tank static too?
CopperNick
3,357
3,018
Canada
My issues and frustrations with the Van's FI TEch unit are posted elsewhere so not going to relate them here.
Did manage to get into the shop before it got too hot and dropped the second new brake line into position. Had to extract it and re-run it once or twice to get it on the right side of all the rest of the plumbing and wiring but it slipped right back into place and lined up in the engine bay with the ABS distribution block without too much encouragement needed.
Underneath i did have to massage some of the curves and bends to get them to follow the basic path of the old line but got it close enough that it bedded into the factory clamps which then closed fairly easily. The biggest bit of fiddling was to get the other end over the frame rail and shaped to fit into the default path for it as well. After that a bit of twisting and tweaking and the fitting lined up with the hose end and all was well.
The yard man from the Auto Salvage yard that I regularly visit does side jobs and he has agreed to give me a hand to bleed the whole business. It will have to be a complete four corner bleed as i don't know how much fluid the back circuit lost. The fronts pretty much were dry and what I put in for the brief journey from the front drive to the shop bled out on the floor of the shop almost as soon as I got the unit inside.
Tomorrow is a work day so i get to see if all the adjustments that I made to the ECU's programming get remembered or ignored. Think the first thing i will do after start up is to revisit the ECU's learning center and make sure all the toggles for the learn routines are on and active.
Ugly1
1,636
1,369
Truck update. I'll have my heads by the weekend. Tonight Leo picked rust with a welding hammer while I wire wheeled all the bad spots. Then he scuffed the bottom of the cab while I wire wheeled the frame and beat off scale. I'm not going to crazy I'm not pulling off all the lines and harnesses simply because I'm to deep in this thing as it is. I'm just making it better not restoring it. So the bottom of the cab is ready for Rust-Oleum rust inhibitor and I have about 3ft of the driver's rail and some of the cross members. So hopefully tomorrow after work I'll get all the rust treated and get it painted black. View attachment 203983 View attachment 203984 View attachment 203985 View attachment 203986 View attachment 203987 View attachment 203988
It's definitely going to need a left rocker soon but it's not going to get done now. I'm just spending way to much money to start doing the body now.
So these were my weapons of choice this evening View attachment 203989 View attachment 203990
The cup didn't work as well as the knotted wheel and there was only 1 small casualty. When I was doing the right rail in the back by the bed the wire wheel caught an edge on one of the frame brackets and ripped out of my hand. View attachment 203991
It's just a leg I've got another one so I kept going until 9:00. That's it until tomorrow
Rough way to to try hair removal. Not sure if it’s better than 36 grit grinder disc.
Ugly1
1,636
1,369
Well, the F150 that got new plugs and had the O2 sensor plugged back in ( went back to muffler shop where they oops’ed, but was all cool) got a true test drive. And the rear brake seized. Won’t know until I pull it apart to see if it was the e-brake ( possibly fixed at a garage) or the caliper seized.
Smoked it pretty good though! The blue oval and age strikes again. Have to admit the motor ran pretty good 🤣
Clutch
5,189
10,913
Brick NJ
