What do I tell the driveshaft shop?
MrSony
6,828
6,736
Des Moines, Iowa
Need a driveshaft for my 8.5 swap, so sometime this week I'll be going to my local 'shaft shop (giggity) and placing an order for one.
Short shaft th350, 8.5 as mentioned.
I know a GN driveshaft would drop right in, but those are nowhere to be found, plus they're at least 31 years old at this point.
So, if I understand correctly, I need a 51 1/2 inch (center to center of UJ) with a 3" diameter tube (preference), with a 27 spline Th350 yoke and 3R/1344 U Joints... is that correct?
Any input appreciated as always.
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,215
Upstate NY
I measure. No guessing that way. No way for a suspension swap of parts to create an error.
565bbchevy
9,614
12,683
Michigan
Measuring is the only way to make sure and eliminates any variances
Reactions: 7 users
RegalBegal
705
747
Goldsboro, NC
Yep 51.5 is the correct lenght for a GN driveshaft. Another way of looking at it is, with no other changes the 8.5 requires a 1" shorter driveshaft than what you have in there now. You could check your math that way. As far as u-joints, 3R's are stock but others can be used. Mine uses a 1310 up front and a 1310/3rR conversion joint in the back. Thats just the way it came from Southwest Speed.
  • Indifferent
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If your driveshaft is in good shape why not have it shortened 1" and re-balanced. If you want to get a new tube it's not too expensive.
when you get the driveshaft back mark the orientaion of the slip yoke so if you ever remove it you'll put it back on the driveshaft the same way. It's balanced with the slip yoke installed and if you put the slip yoke on 180 reversed you can cause a vibration.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Just shorten what you have. Save your money
You aren't making any power to justify anything else
MrSony
6,828
6,736
Des Moines, Iowa
I cant shorten my driveshaft. Its my only car. I cant have it down for a week.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
A week???
the shop by me has them done in a couple of hours
I guess you dont have a shop near you
