I just threaded to return port directly on to the hard return line. Planning on adding a support to keep it from vibrating too much. Anyone else done this and if so did you have any problems?
I have made quite a few AN hoses and to me that braided line looks too small for the AN hose ends ( which appear to be some Ebay ones) and I personally would have made a bracket for the regulator and mounted it somewhere else to avoid using a 180 fitting and give it a cleaner look. IMO
It appears to be thick enough to drill and tap to install it there.I cut two slots in the ac bracket and used a couple of bolts to mount the regulator there View attachment 114983
