What does it take to put an 8.5 into a 7.5 car?
MrSony
6,826
6,729
Des Moines, Iowa
Is it literally a drop in swap? Do I need a shorter driveshaft, or is that only when going to a 200r4? What codes on the rear should I look for? Asking for a friend... ;);)
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Unbolt the 7.5, unhook brake line, remove. Bolt in 8.5 and reattach brake line.
Shorten driveshaft by 1 inch and rebalance.
Th350 and 200-4R are the same length.
Check fluids, and do burnouts :cool:!!!
Reactions: 8 users
-83MONTESS-
4,570
967
Bellevue, Ohio
Mine required a 1" shorter driveshaft but I have heard others say 1.5" depending on car. Doesnt make sense to me but whatever
MrSony
6,826
6,729
Des Moines, Iowa
:D
  • Creative
MrSony
6,826
6,729
Des Moines, Iowa
I doubt the DS would care about that extra half inch. Unlike some girls I used to know....
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,181
Upstate NY
The driveshaft length is affected by several variables - yoke on rear, suspension height, trans/engine angle, transmission model,etc. I do agree that it should be relatively standard, but if you're swapping the rear or transmission that is going to result in a driveshaft length change, then that is the time to optimize the length rather than dropping off an inch and 'calling it good' IMHO.
It's also a great time to upgrade to a heavier shaft (tube) and u-joints if you're making alot of power, or plan to in the future.
  • Winner
lilbowtie
3,460
3,965
Canton Mi
I'll get on my soap box again and ask you to take a look at "drive shaft critical rpm". Depending on the rpm range your planning on running it can have devastating results. Google - drive shaft critical rpm, Precision Shaft Technologies has a nice chart.
  • Informative
foxtrot
1,489
590
USA
Holly cow, that's gruesome! Hopefully nobody was injured with that carnage.
Definitely a good tip to take to heart.
8,819
7,765
Melville,Saskatchewan
Another reason to use the factory, shorter heavier duty 8.5" drive shaft if you can get it with the rear.
