I should have mentioned in running a fuel cellI’m running twin walbro 450s, that set up/goal
Terminator x maxIf running a cell, get you a magnaflow 4505 if I recall. It'll be plenty of pump.
What ECM you running?
Why do you say thw 4303 is not street friendly?The biggest, baddest deal for your goal is a Magnafuel 4303. It can be driven via PWM, which is fabulous - your Term X can handle that. It is not the most street friendly setup though.
The budget program is the twin Walbro 450's (in tank) or AEM 380's (external). I'm running 2 380's as opposed to Chris's twin 450's. Both will get the job done - easy to get parts and setup. If I wasn't such a cheap *ss and was building a strip only car, then I'd be onto using a 4303 without even batting an eyelash at the decision.
