What headers have the best chance of fitting without modifiation?
Down Shift
12
13
HI,
First, car is a 1979 Malibu with a SBC350 with Vortec heads and a TH400.
I bought a set of Flowtech headers (31104 FLT), and they fit fine, but the driver's side header had a bad weld so they went back to Summit. I just exchanged them for another pair. With the 2nd pair, the passenger side header interferes with the rearward front lower control arm mount. I am going to send them back, but I'm not sure I want to roll the dice with Flowtech again.
What brand tends to fit best? I would prefer stainless or ceramic coated.
I did a search, but my search-fu must be weak because I didn't come up with anything.
Thanks!
565bbchevy
9,590
12,611
Michigan
I bought some stainless Ebay headers that fit very well, I had to notch the driver's side clamshell and because I have a column shifter I had to modify the linkage.
Here is the thread about them.
Down Shift
12
13
Thanks for the suggestion. For better or worse, the first set of headers I bought were stainless ones off Ebay. The listing said they would fit a 1979 Malibu. There was so much interference between the passenger side header and the frame that I couldn't even bolt them up. They were totally unsusable. Maybe I just chose the wrong Chinese headers?
I've been through 3 sets of headers now and none of them have worked out. I just want to buy something of decent quality that fits and be done with it.
Doug Chahoy
2,564
2,661
I tried Flowmaster 1st, did not fit at all. Bought Hooker SS, alot of issues but got them to work. If I was to do another G body project I’d go with shorties
roger1
537
767
San Angelo, TX
Hedman 66609 fit great in my El Camino. The 66609 are for D port heads which my LT1 has. I do believe they make the same headers for regular ports too. Not sure what the number is for those.
Down Shift
12
13
Well, I just decided to "fix" the Flowtech headers. I know I damaged the ceramic coating and they will rust in that area, but by golly now they fit with 1/4" of clearance!
On to tackling other problems with this build...
Thanks for the responses!
