What headers will fit on my 1986 monte carlo. With a big block 427
M
Monte carlo 1986
19
What kind of headers can i use for my 1986 monte carlo im putti g a bbc 427 in it
GuysMonteSS
GuysMonteSS
1,169
Kentville,Nova Scotia,Canada
Hooker make a set of swap headers,# 2241;
https://www.summitracing.com/int/pa...ew/year/1986/make/chevrolet/model/monte-carlo
"A" Body Chevelle headers will also fit with a bit of work;
https://www.summitracing.com/int/parts/hok-2455-1hkr
These are what I have in my BBC Monte and here is a link to a blog I made a few years ago on what it took to make them fit;
http://guysmontess.blogspot.com/2011/10/body-headers-to-fit-bbc-g-body.html
Unless you are building an all out high performance 427 a set of smaller tube "A" Body Chevelle headers might be a better choice,like these ones;
https://www.summitracing.com/int/parts/sum-g9010/overview/
The smaller 1 3/4 inch primary tube will likely fit a bit better and still give good performance.
Guy
M
Monte carlo 1986
19
Guy
Yea not a high performance build just a simple rebuild for a daily driver
GuysMonteSS
GuysMonteSS
1,169
Then you don't need the 2 inch tube headers.
They would kill your bottom end.
Guy
Reactions: JAMCAR223
454Regal
454Regal
n00b
Nov 24, 2018
2
No denting but I did move my proportioning valve , right under the master cylinder
GuysMonteSS
GuysMonteSS
1,169
How many threads do you need on the same subject ???
Maybe a moderator could merge them into one...
Guy
GuysMonteSS
GuysMonteSS
1,169
2 inch primary tube headers will be too big for a Lo Po 427 build.
Guy
