What kind of screws for corner lights 84-87
shawn1112
165
136
Did the 84-87 header swap on my 83 Regal. Bought new aftermarket headlight bezels and corner lights. I was able to source new hardware for bezels but not the corner lights. They appear to screw in to plastic housings on the bezel. But not sure what type or size of screws to use? Don’t want to screw up brand new bezels with incorrect hardware.
Thanks in advance.
69hurstolds
8,195
17,594
Assuming the diagram below is what you are needing (corner lamp #13)
M4.2-1.41 x 25mm (#10 in diagram)
GM p/n 11505182 (discontinued, of course)
Clips and Fasteners will sell you a box of 50 for 11.99 plus shipping.
https://www.clipsandfasteners.com/Ss-Torx-Oval-Head-Tap-Screw-M4-2-1-41-X-25mm-p/a14053.htm
Also it MAY call out for M4.2-1.41 x 30 mm as well (#15 in diagram) GM p/n 11504656. Same screw as above, but 5mm longer for whatever reason.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
You can also find them screws at Lowe's in the hardware section(look for the automotive slide out drawers). Also, most Do-it-best hardware stores have them in stock as well.
