what mounts for my cutlass 1972 supreme
Mrgain72
n00b
Jun 27, 2010
4
can someone tell me what motor mounts i need if im going to put chevy 350 ..??
some people tell me to get mounts from a chevelle but i dont know what year ..??
pleas help...
i need to get ma car ready...
68-72 Chevelle. You have to bolt the correct Frame Brackets in the Correct Mounting Location and then get the correct engine block motor mounts. Then if you are running a HEI you will have adjust the firewall for the distributor to clear. I have done this type of engine swap quite a few times.
anakputa said:
...Then if you are running a HEI you will have adjust the firewall for the distributor to clear. I have done this type of engine swap quite a few times.
Again, that must be another one of those superior Chevy "features", since there is absolutely no firewall "adjustment" necessary to use a HEI on an Olds motor in any A-body car.
