That appears to be a Borg Warner 7.5" locking differential also known as an Auburn.
From the GM Illustrated parts catalog: Page 5-17
Note: IF CASE, CLUTCH CONES OR SIDE GEARS ARE DAMAGED, IT S NECESSARY TO REPLACE THE CASE ASSEMBLY-GROUP 5.510.
the cover has 10 bolts though and I think all the BW were 9 bolt and 7 5/8
https://www.drivetrainspecialists.com/gm/gm-775-9-bolt-borg-warner/
That is a "Australian Borg Warner Rear End" that also used a Borg Warner Differential.
B&W cone style positractions were a factory option on 7.5's until about 1985. 8.5's got Eatons.
"Auburn Gear" was spun of from Borg Warner around 1988, so there was no "Auburn" differential factory installed in a G-body. It was a Borg Warner" differential.
that's interesting but I can't find any info on that. The F body forums if it's a 9 bolt they call it a BW but they refer to the 10 bolt as an Auburn. I went to the BW site and tried to look up the rear ends they put in GM cars but came up empty. The only thing they had in GM passenger cars was a small turbo. I found the BW 9 bolt were used in F bodies from 85 to 89, the 10 bolts were used 82 to 92. Do you have any links you can share. I like reading about these little know facts....
http://sethirdgen.org/reardata.htm
Thanks, I turned to to save my neck...The retainer plates look flat on the ops so I don't think he has the 10 bolt WD. Do you know if these had a bolt in axle like the other BW rear and if they were stronger than the Auburn
