the stock vortec heads can handle between .500 to .550 lift max in the average best case scenario. In all honesty you should upgrade the valve springs, it is pricey but worth it and although the 1.5 roller rockers are 100x better then stock a 1.6 would have been better usually. That being said I have a vortec 355 in my truck with stock heads but a bigger cam, headers, cold air, and just a base tune in the computer and it woke the engine up a lot. Its pretty snappy in my 5,000 lbs truck and I have ran low to mid 15s 1/4 mile times(yes I know not that fast but not bad for a 5,000 lbs truck. Stock is low 16 sec). I also don't have a stall. From what I have seen the vortec heads flow very well for torque and if you port them you will gain hp but lose a little bit of torque. But as said in a previous post its not all about lift. Its about getting the parts that go along with it like the intake, carb, stall, etc. Comp does make nice cams for those engines and better valve springs will run I think 200$ through comp but handle around .650 lift I believe.
