Is this a street engine?? I'm almost assuming it is. First off don't even think of using a Tunnel Ram on a street engine, unless you'd rather be tinkering & tuning instead of driving it.
Get a dual-plane intake like a Weiand Stealth, Holley Street Dominator, or Edelbrock RPM.
Now back to the cam. Is this 275* advertised or @.050?? If it's at .050 FORGET IT. Anything over 240* @.050 for a street engine is pointless. First off, you are dealing with a small displacement engine that's not making alot of low end torque. Torque is what shines on the street, not screaming high RPM horsepower that you rarely get to use. Not only will you not be making sh*t for power under 4,500 RPM'S with a way too big cam, you'd need a stall converter of 3,500-4,000. So now you'd have a useless engine with a narrow powerband that would get burned from a stoplight by a Pinto, get my point.
Pick a cam with NO MORE than .480-.500 lift, 230* duration @.050, & is ground on 110* lobe center. This cam will still have a choppy/mild rough idle & will make great low end AND high end (to 5,800) power.
Also, what's your comp. ratio & what are the heads you are using??
