What Tire Size? 15x8 Wheels
kustomss
217
16
I'm looking to buy a new set of tires for my '85 Monte. It has 15x8 wheels and I plan to lower the front and rear about 2". I was thinking a set of 225/60s would look good, but I'm not sure. What are you guys running?
cadtiger84
17
It depends. Are they stock wheels or aftermarket?
Kwik_Cutty88
1,173
662
Coastal North Carolina
I've got 235/60/15's up front and 275/60/15's out back also on 15x8" wheels.
kustomss
217
16
They're aftermarket aluminum wheels
Doug213xrj
1,529
131
West Michigan
I run 215/65/15 on the front and 245/60/15 or 295/50/15 on the rear.
Doug
cadtiger84
17
Well you can get a wider tire if you have more back spacing on the aftermarket wheels so check to see what the difference is and if its the same then 245/60 is about as big as you can go but it you get more back spacing with with the aftermarket then it will depend on how much
breeaad
164
5
Hendersonville Tennessee
I think you mean less backspacing.
cadtiger84
17
Yes that's what I ment sorry I said it wrong
