So I removed the AIR system from my 86 Monte. I just can't figure out (or maybe I haven't tried hard enough) what to do with these two Lines. One was a large tube going to the air filter, and the other is a vacuum line that looks like it goes to the carb. Check out the photos. I circled the one where the two vacuum lines end up. At that spot there is also what looks like a spot for another line that isn't there... Not sure what any of that is.
ALSO! I can't seem to loosen the bolts that hold the brass fingers from the AIR system into the manifolds. Has anyone just cut these off and plugged the holes?
