You have a TH-200 or TH-200C They are both 3spd transmissions, one has a Lock-Up torque converter. You can tell by the number of pan bolts and if it has a factory trans pan on it then it will say "METRIC" on the bottom thats why people call them "200 metric" It's a grabage transmission built for mileage not power or reliability but its the same length as a TH-350 and uses the same crossmember bolts so it is a direct swap. As far as the reverse being out, check your linkage and make sure it is engaging the gear. If so you might have lost it completly, reverse is very weak in those transmissions!
