What Transmission is in your Ride?
  • Total voters
    46
  • Poll closed .
MrSony
6,793
6,678
Des Moines, Iowa
Title says it all. I'm betting Th350 will take this one.
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
Was a Saginaw 4-speed. Will be a T5.
565bbchevy
9,591
12,612
Michigan
TCI full manual competition th400 in the Monte and a 200r4 in the Regal.
454GrandPrix
429
818
Lehi, Utah
First vote for a 4L80E here.
I had a Cheetah reverse-pattern manual valve body in my street/strip Dodge Caravan. Man, I miss those days.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
TCI streetfighter TH350 that I've had since '03 and have beat the living snot out of! In auto mode it shifts hard, in manual mode i can blow the tires off into 3rd gear.
383_StealthRam
176
389
Not to get overly technical, but....mine's actually a 1993 one year only version of the 4L60 that was sold by GMPP (Performance Parts) and was the last year of the 700R4 before they moved to 1994 up "E" electronic shifted versions. It was based on the 1993 Camaro Z28 3FMM code, and has the round 5 pin electric connector vs. the 4 pin square connector on all the previous cases. (see attached)
I had it recently built by http://www.fbperformance.com/, with upgrades such as 5 pinion planetary gearsets for increased torque capacity over the stock 4 pinion setup.
Just figured I'd share a little knowledge nugget from back in the day relevant to this survey question.
