What transmissions fit my 86??
north chicagoland area. wouldnt I have to do a bunch of mods if i use anything besides the th350 or the th200? I want a bolt up typed deal.
Not sure why we'd suggest a 700-r4. Truth be told that's a truck transmission. If I were upgrading to overdrive the 200-4r wins hands down. There is NO factory crossmember, the 700 is pretty large, you'll haveto cut the driveshaft, gearing isn't as good as the 200-4r .... plus I am assuming his Cutlass has a Buick V-6 or an Olds V-8 .... I don't like the idea of adapter plates to mate to Chevy only bolt patterns .... every 200-4r I've seen is uni-bel. If built right (keywords) the 200-4r can even take more torque.
Bolt-in leaves another weak th200c or the th350
I agree.I was having a brain melt down for a second there and thought he was driving a chevy...BTW, I have a 700-r4 in mine and LOVE it 😀
Yes, things are pretty dry at the yards here in terms of BOP / g-bodies & parts.
When asking make sure you state you need a BOP bolt-pattern as the Chevy is different. If the trans is out of the car already take some cardboard and make a bolt-pattern template. This way if you find one, when you go to check it out you'll know if you got the right one. I mean, there are some uni-bolt pattern TH350s but they're kind fo few & far between. And of course check the fluid, pull the pan if possible to see if it smells burnt or if there are shaving / grit in there. But I agree with all here, go straight for the TH350.
Have you tried the yards in Elgin or N. Aurora? I just helped a buddy do an engine swap on a Wrong-Wheel-Drive Monte Carlo and he picked up his engine from, I believe, Midwestern Used Auto Parts. Or try Super Auto Parts, they are a recycler. You can also look in the Trader mags.
Wish you were closer...I just parted out an 83 Malibu 4dr with a Buick V6 in it...the trans is a TH 350C with a pretty low mileage rebuild...and I can't use it.
got that beat, I'm just outside of St Louis. I gave away a perfectly good uni-bel th350 with a shift kit - simply because I didn't want to put it in storage (was 40 miles from the car at the time) when I yanked it out and put the 200-4r in.
now why would I be on this website asking for help if I was gonna get a new one? :blam: sh*t I could have bought a new one without ever posting one question. The whole point is I want to get one used....drive it until it goes then rebuild that one the way I want it. For $700, probaly closer to $800 with uncle sams cut, I can build up any 350 to my specs. Plust when I do my rebuild I want to put all the upgrades and stuff in it.
well if you cant use it why not donate it to me. Ill cover shipping costs from canada to the chicagoland area....cmon be a pal
