What type/brand fuel injectors are you LS guys using?
wskirvin
324
423
Indianapolis, In
I picked up a set of Holly 42lbs injectors they they had on sale a couple years back.
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,215
Upstate NY
60lb or 80lb Dekas for any gas application. Depends on HP goals, but the 60's will run to 750hp naturally aspirated and the 80's to 1000hp. Knock a couple of hundred ponies off those numbers if you want to throw some boost at them.
They are ultra reliable injectors for $400-450.
What are you planning to do with your car? HP wise, fuel wise, power adder?
81cutlass
4,649
13,565
Western MN
Siemens here. Stable and affordable.
If 80's aren't big enough Bosch 220's are basically the next step up.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Deka 60lb here. Be VERY careful of knock off Chinese Deka injectors. If the price is less than $350, they aren't real Dekas...
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,827
Red Deer, Northern Montana territory
This right here is the first thing that needs to be figured out.
Do you want a crisp clean idle? What is your base fuel pressure, do you have a return style fuel system, what do you use for fuel filters, what do you have in the fuel system?
It's not just slap in whatever and send it.....
Steve 82 Elly
105
110
I'm looking for 500 - 550 hp N/A
Steve 82 Elly
105
110
Plans for the car are a Street/strip build with an emphasis on street (I want to drive the car alot) but respectable at the strip (mid to low 12's).
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,215
Upstate NY
Are you using an aftermarket ECM or stock?
