The Wilwood dual piston aluminum caliper has a smaller piston area, so the clamping forces are less. There is not much of a weight difference between this and a Wilwood oversized 2.75" piston caliper.
The Wilwood oversized 2.75" piston caliper has a larger piston area, so it should give you better clamping forces.
IMO, the biggest downfall is the rotor diameter, so if you are going to spend money, spend it on a total aftermarket system that uses a stock spindle.
If you are going to keep the stock front rotors, go with good aftermarket pads first and just replacement calipers. Upgrade to stainless steel braided flex lines front and rear. If you are keeping the vacuum boosted system, upgrade with the b-body 12" dual diaphragm vacuum booster and a right hand drive 2000 S10 1.0" bore master cylinder (must be a right hand drive S10)
This master bolts right in no mods and actually works AC DELCO Master Cylinder Part # 89056529 or 18M974 (same master)
maliburacing.com
Im doing the booster upgrade this weekend and was wondering about the master cylinder as well.I will be running ls1 brakes out back and c5 corvette brakes up front, would that master cylinder be a worth while swap?What about the proportioning vavle? Do the B bodies have one? If so would ...
www.montecarloss.com
If you're like me, you've hated the feel of your stock brakes from day one. In my case, it literally was on day one, driving the SS right off the dealer lot in 1986. I even returned the car and complained, but was told "it's normal". The pedal has an extremely soft fee...
Good pads, new rubber lines or stainless steel braided flex lines, and a fluid flush will make a big difference. Going to the B-body booster and S10 master cylinder will make it better.
