Whats the best way to remove window tint?
ERIC87442
615
16
Monroe, Wisconsin
so, my cutlass has the rear quarter windows tinted on it and thats it. i want to know how can i remove it nicely? it looks as if it is glued on, the previous owner removed the tint from the rear window because it was bubbling and there is a bit of goo left over from it, i dont want that. so, how should i go about this?
FE3X CLONE
2,714
47
48
Ohio
pontiacgp said:
grab a corner of it and pull it off...then use goo be gone to remove any adhesive
Yep. The film is removed pretty easily. The glue just takes a bit more work but an ahesive remover should work.
ERIC87442
615
16
Monroe, Wisconsin
thanks! i was thinking something along that line, i didnt know if there was a special trick to it or something and i didnt want to screw something up and make my windows look like crap, i will get me some goo gone and give it a try! ill try the goo gone on whats left on the rear window too.
FE3X CLONE
2,714
47
48
Ohio
The only tricky part with window tint is removing it from the rear window if it has the defroster lines. Just be careful cleaning it so you don't screw them up.
85GPLef41
2,210
159
Colorado
I removed the old tint from my 79 GP with a razor blade. It was so old it was purple! I then cleaned the windows with WD-40 to remove the adhesive and then with some Windex to clean the smears. BUT my 79 didn't have a rear defroster though which made it so much easier. 8) I have heard of "sweating" it off but have never seen it done before!
redboy504
206
16
New Orleans, LA
It's actually pretty easy. Do what the pro's do. Peel it off like everybody else says. But to get the glue off use a solution of dish soap and water. Then scrape it off with a razor blade. It comes off pretty easy. But your arms and hands get tired. Then clean the glass off with glass cleaner. I've done it a lot. It works.
1evilregal
3,056
4,357
Greensboro, NC
there is some stuff you can get at most parts stores, that is specifically made for this
Phoenyx
2,392
7
Alberta, Canada
Take it to a tint shop to get it re tinted. Then they have to worry about it lol.
