Wheel Fitment Guide
Kamloops cutlass
411
536
Kamloops bc
NOT YET ..STILL KINDA TORN..
SET OF 17" ON ALL 4 THEY WILL WORK BUT NOT SURE IF THEY WILL LOOK TOO SMALL AND THINK IM GONNA WANT MORE WHEEL IN THE REAR
OR 18/20 " BUT HAVENT SEEN ANYONE TUCKING 20X10" IN A STOCK REAR FENDERWELL ??
Sorry I missed your reply
Those 20s look pretty big , not sure how they’d fit
What do they measure ?
Kamloops cutlass
411
536
Kamloops bc
My wheels came (then I did) very happy with the fit and I appreciate the help you guys gave me
Here are the specs so other can benefit from the knowledge
Kamloops cutlass
411
536
Kamloops bc
Sorry I couldn’t figure out how to add text after the photos
Anyway...
Front 17x8 4 3/4 backspace 245 45 17
Rear 17x8. 4 backspace 255 45 17
Tires are BFG sport comp 2
Wheels torq thrust 2
There is a slight rub at full lock on the inside fender skirt
Back tire has room against frame rail but I bet a 4 1/2 bs would rub with any tire bulge
Kamloops cutlass
411
536
Kamloops bc
Also has not been lowered but original springs may be sagging ?
If a mod could put these last 3 posts together that would be awesome lol
Thanks again guys
Steering box next !
403Olds
532
421
South Central Ohio
Nice looking rim and tire combination. Thanks for posting the specs. Seeing yours really makes me want to pull the trigger on some 17's....
Kamloops cutlass
411
536
Kamloops bc
Thanks I’m pretty happy with them , the staggered backspace front and rear makes a difference in both looks and fitment
Makes the back wheels have a fatter lip making the back rims look a little wider than front
Wish BFG had made a 255 50 17 but once I get it lowered a bit the wheel wells will look a little fuller
Dec 9, 2021
4
I have a 1980 Chevy Malibu. It currently has 215/70R14. I have a set of wheels that are 245/35R20 but are too wide. I was wondering if camaro wheels could fit. Say 2010 and beyond. If anyone has some advice, I’d appreciate it
scoti
1,972
3,386
Texas
Wheels are not measured in p-metric sizes; tire are. Different things that impact what can fit:
*Wheel width
*Wheel offset
*Tire size
*Vehicle ride height
*Suspension set-up
Camaro wheels are going to have tires as wide as that 245/35 width you posted.
Dec 9, 2021
4
*Wheel width
*Wheel offset
*Tire size
*Suspension set-up
My bad. Can I fit camaro tires on the Malibu?
80/MALIBU/COUPE
107
165
TUCSON AZ
JUST GOT WHEELS FOR MY 80'
18X8 FRONT 5" BS 235/40ZR18
18X9.5 REAR 5.5" BS WITH 1/4" SPACER I HAVE CLOSE TO 1/2 INCH BEFORE FRAME ,
TIRE 235/40ZR18 AND IM STRECHING IT . GOIN TO 275/40R18 MAYBE WIDER "285/295" I GOT PLENTY OF ROOM WONT EVEN HAVE TO ROLL THE FENDER I DONT THINK BUT I PROLLY WILL JUST TO DO IT IN CASE I PUT A BIG PUFFY DRAG TIRE BACK THERE
IM PLANNING ON LOSING 1-2 FRONT AND 3-4 INCHES OF ALTITUDE IN THE BACK
I MESSURED JUST SHY OF 6" BS ON BOTH SIDES .
CAN EASILY PUT A 10" WIDE WHEEL IN THE BACK WITH 5" B/S .. BUT BUY AT YOUR OWN RISK
