Yoda said:12mm dia. X 1.5mm pitch is correct.
FE3X CLONE said:Yoda said:12mm dia. X 1.5mm pitch is correct.
For '82-'88 it is. For '78-'81 its 7/16-20.
The '78-'81 also take a different outer wheel bearing compared to the '82-'88 spindle. So you'd want to double check before swapping brakes around. I don't remember if its the spindle size that's different or if its ID of the brake hub thats different in size.
pontiacgp said:why not just change the wheel studs to suit your needs
