Did you check with any Bonnevilles?
Believe the 4 door trim should fit. I check my Chevy catalog & it list the same p/n for the Malibu on both. In theory since Chevy & Pontiac used the same body shells you should be able to use a set off a Pontiac 4 door.No I haven't They didn't make 2DR so don't work?
That's if I can find one..Believe the 4 door trim should fit. I check my Chevy catalog & it list the same p/n for the Malibu on both. In theory since Chevy & Pontiac used the same body shells you should be able to use a set off a Pontiac 4 door.
Post an ad in the wanted section. There are guys on here with lots of parts and guys who are frequently in the yards.That's if I can find one..
Basically that's why its no god damn hard too find..The trim will have to be from a LeMans, Grand Am, or Bonneville. The GP won't work on his car.
