The center carrier support bearing in my 95 F150 needed swapped out, so I pulled the driveshaft and called around. I figured while it was out, I'd have the shop inspect the yokes and u joints and balance it. I called three different shops and all of them wanted $200! Luckily I knew a guy who knows a guy who replaced the bearing, checked the u joints and yokes, balanced both halves and greased it up for $75.
When did it get so expensive though?Hell, I remember several years back I had a driveshaft made from scratch when I put a 14 bolt in my 1/2 ton Chevy and I think it was only $225 or so. What are you guys paying for driveshaft work?
PS- if you're in the Pittsburgh area, AVOID Driveline Service of Pittsburgh in Lawrenceville. I've heard of some real junk coming out of there. If you need a recommendation, PM me.
