Where does the engine go?
barncar
17
Miamisburg, OH
I got the 3.8L/TH200 out of the '84 Cutlass, and suddenly I see way more holes than I am used to seeing for locating the motor mounts. I know I can use Monte Carlo mounts, that isn't a problem, and I have a set of clamshells for the block... But I have too many holes for me to just guess about where the mounts go, and I don't want to have to put 'em in more than once.
dougfather
286
5
16
Altoona PA
barncar
17
Miamisburg, OH
Yeah... I have 3 sets of mounts for different cars and different engines, and the Buick 3.8 mounts are definetly wrong. The 2.8L and 4.3L S-10 mounts I had laying around are close, but not wide enough. I can get the Monte Carlo mounts for about $7 apiece (new!), so I don't see any real trouble with everything except the placement. Thanks for the links!
jerrycad472
264
16
Detroit, MI
Dougfather is right, one hole on the engine mount hangs out slightly past the cross member, so you only use 3 bolts. Its been to long for me to remember which one, but hopefully the links will show you exactly what you need. Good Luck.
82355supreme
244
Wisconsin
You'll only use 3 of the 4 bolt holes on the mount. The un-used hole will actually hang off the cars frame toward the front of the car.
Just move the mount around 'till 3 holes line up & 1 is hanging off & you'll have figured out the magic combination.
