Which book would be more useful?
UC645
1,083
3,072
Kittanning, Pa
Keeping a long story short, I picked up a Quick Fuel 650SS this weekend and it’s basically brand new. However, it has been sitting around a while. Smells like it had gas run through it but it didn’t sit around with gas in it, the bowls are spotless aside from the smell.
I don’t have any Holley books to go by for either tuning or rebuilding and have been going off of internet resources (forums) since I started.
I’m just going to run some carb cleaner through the new carburetor, then I’ll be putting it on my engine since it looks brand new.
And in this case, which of these books would be more practical to have right now?
The Rebuild book
Or the Tuning book?
Rktpwrd
Builder of Cool Shjt
4,167
23,917
Calgary, Alberta, Canada
Tuning book until you’re ready to tear it down.
Ernest
742
1,000
Texas
Definately David Vizard's tuning book.... if you look him up on YT, he has a wealth of great information to share with the hotrodder/racer communities, if you want the most and best out of your engine builds, you listen to this man religiously.
In addition to his books, may i suggest you get an AFR and vacuum guage setup, great devices to date to help you tune that carburator correctly... be aware you are in for a major tuning ride with that carburator, it has adjustable air bleeds throughout(main body/metering blocks) to custom taylor the fuel curve to your engines needs.
UC645
1,083
3,072
Kittanning, Pa
Got the book yesterday, and I’m actually astonished by what’s in it. All I really wanted for right now was the proper initial settings for a 4 corner idle carb, and I ended up reading for 3 hours.
I’m fairly certain I have a good vacuum gauge I used to attempt to tune the 600cfm Holley, but while I’ve got an AFR gauge, I can’t install the sensor. Too many spiders and too much dirt under the car right now. All I want is for this thing to start the car consistently, rather than needing to fight it every attempt.
And I’d rather deal with the semi-known quantity that this 650SS is as opposed to the impromptu hammer that I bought a year ago.
