Which speedometer gear?
Wageslave
1,747
3,335
What size (color) speedometer gear would I need for a TH200c with a 2.41 rear gear ratio and factory tires. My speedometer is currently running 10% too fast.
UNGN
3,048
3,264
Southlake, TX
Its all about what you have now to what you will need. There are too many variables in tire height for someone to say you need X, unless they are running the same make tire and their driven gear/drive gear combo could is the same.
If you currently have 2.41 gears and the speedo is reading fast, the only gear lower is 2.29's, so your trans probably has a 2.29 drive/driven gear gear set in it.
Does it currently have a 18T driven gear?
Wageslave
1,747
3,335
I am not sure yet. I will be pulling the speedo drive out this evening. I got this transmission off the shelf from a junkyard, so I am not sure what it originally came from.
