I’m considering adding in oil cooler. My L92 had one when it was in the Escalade but it’s long gone. I’m looking for ideas for which cooler would work best and where to mount it. Anyone out there with a Cutlass that has been through this?
I don’t know what my actual oil temp is and I am not concerned about hitting the ideal OE oil temperature If it’s 200F. Early L92’s were known for low oil pressure and mine is no exception when hot. At cold start up the oil pressure starts very high but when running on a hot summer day it will drop to about 20 psi at idle. This engine has only 45K on the clock. Since my engine had an oil cooler from the factory it will be just fine.180 is a little cool for the oil, OE spec would be around 200 or better.
My 565 BBC in the Monte runs around 200 all day long once warmed up with no cooler but I have 10 quart capacity with dual filters up front that actually get some airflow.
Just give it up already. Like I said my engine came with a cooler from the factory so it’s not going to hurt.That's normal regardless of your oil capacity. Oil temps track with water temps unless you subject the motor to extended high RPM which is why I say the OP does not need an oil cooler. If he has oil pressure issues, this is the wrong way to try and "fix" that.
