who is right
talk to a tech at summit about the vision gold 15x8 wheels im planning to order. was told the wheel i need has a 4.00 backspace.
i call extreme custom pricing the same wheel and they said i needed a wheel with a 4.03 backspace. i did ask both for a wheel that fit 87 salon, vs cutlass supreme as suggested by another member on this site. the offset was the same-12mm on both. so ???? does .03 make a big difference. which one is the best fit. also my goal is to go with 15x7 on the front so if there is any suggestion on the offset and backspace i will need would be helpful
VISION DAZZLER V324 GOLD
Part Number : V324-5861GMF-12
UPC Number : 886821208715
Bolt : 5x4.75
Offset : -12
Hub Size : 83.00
Load : 1800
Backspace : 4.03
2
Brand: VisionStyle: V324 Dazzler Size: 15x8
Bolt Pattern: 5x120.7 (5x4.75")
Offset: -12mm
Backspacing: 4"
Hub Bore: 83mm
Finish: Gold Machined Face
Quantity: 1 Vision V324Dazzler
15x8 5x4.75" -12mm
Bolt : 5x4.75
Offset : -12
Hub Size : 83.00
Load : 1800
Backspace : 4.03
2
Offset: -12mm
Backspacing: 4"
Hub Bore: 83mm
15x8 5x4.75" -12mm
