pimplogic said:lol thanks for all the help guys but now the carbls throttle position sensor is off...
Blake442 said:pimplogic said:lol thanks for all the help guys but now the carbls throttle position sensor is off...
All the TPS does is bump up the idle when the A/C system is turned on to compensate for the added load on the engine.
You can disconnect it if it is interfering, and then double check your idle screw setting and you're good to go.
FE3X CLONE said:Blake442 said:pimplogic said:lol thanks for all the help guys but now the carbls throttle position sensor is off...
The TPS (Throttle Position Sensor) does more than that. The idle stop solenoid is what bumps up the idle, not the TPS. The TPS is what tells the ECM how far open the throttle blades are. It needs to function for the engine to operate properly.
