It's more than what you're probably thinking.
David Freiburger Believes the LS Made the Big-Block Cool Again
LS engine swaps have become so passe that older small block and big block powered cars are cool.
www.hotrod.com
I can't get a visual of what you're describing even after several minutes of hard thinking.Two words describe this article, verbal masturbation.
I'm not saying the engines don't have power - they do.I can't get a visual of what you're describing even after several minutes of hard thinking.
Two words come to my mind that created this revolution - CAFE standards.
Most everyone, including me, has moaned and groaned about emission standards and their effects on engine performance and reliability. But the LS, Coyote, and modern Hemi are the end results of the government imposed CAFE standards of the 70's, 80's and 90's. No one,and I mean no one, in the 70's hotrod world ever considered that you could build a streetable and reliable 700hp build - now it's so common place that that 4 digit power is the 'big power' goal.
There definitely is no replacement for displacement. That’s more than a saying, low rpm torque is not made by any sub 4.25” bore and stroke motor.I'm not saying the engines don't have power - they do.
But their peak hp and torque in many - not all - cases are in ranges nobody every accesses them...
6.2 engine has a peak hp at 5900 rpm... paired with an 8spd auto, how much time are you really running at that peak HP? Probably not much.
I have more fun with an older big block where you're pounding 400, 500 lb ft of torque at 1600rpm and still playing with 300+ hp before 2000 rpm.
But that's just me.
Also remember - the 70s hot rod world didn't have traction control, suspension tech, and tire compounds we do today and very little of which came from CAFE. The limitation then wasn't about unlocking more power... they stopped trying because they couldn't control the power they were getting.
With the coming 'electrification' does that mean the new buzz saying will become "clinging to their guns, religion... and big blocks?"Very good article, IMO, makes a lot of good points. You can’t stop change, you can choose to either embrace or resist it.
You left out an option.....or just ignore it. And to think, Hurst started out as an engine-swap component company...Very good article, IMO, makes a lot of good points. You can’t stop change, you can choose to either embrace or resist it.
