MALIBU Widest rear tires
565bbchevy
9,611
12,670
Michigan
Assuming 15" tires most Gbody's fit a 275/60 or 255/60 depending on rim width and correct backspacing without a frame notch.
Lowered ride height also affects tire width.
The best way is to measure off what you already have then get the specs for the brand and size tire you are looking at.
Reactions: 4 users
carnutjw
624
1,469
Or find a buddy with similar size wheel/tire combo, try them on your car, take some measurements, and go from there. Some claim a 275/40-17 will fit my car, but I have less than 5/16" clearance on each side with 255/45-17's on a 17"x9" wheel- 275/40 is currently a no-go with lowered height, 9" wheel, and no fender well mods.
fastNYsix
102
147
285 35 18 stock height. No notch, no fender roll, no rub on regal
Reactions: 5 users
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
Depends on the car. An 84 Monte Carlo has more room than an 80 Cutlass - by 1/2". 275/60R15 fit in the 80 Cutlass and and easily in the 84MC .
Reactions: 4 users
liquidh8
Really depends. I've 275 50-15, 275-60-15, 275-45-17, all on a gbody. I rolled the lip though. Also, alot of these gbody have work out body mounts and no longer sit square on the frame, so clearance on one side may differ from the other. I've had this happen more than once.
Reactions: 5 users
clean8485
2,861
2,144
Ontario, Canada
What's the backspace on your rims?
carnutjw
624
1,469
