So the wife's 05 Yukon xl turned 260k
It needs tires no biggie
But front end could use some work not lose parts but I see the wear like upper and lower control arm bushings so I'll get them but while I'm there going to do upper,lower ball joints ,sway bar link pins. This truck has autoride z55 code but the compressor hasn't worked in years rear shock air bags are torn rides fine but since I'm doing all this work might as well put new shocks on has anyone converted there factory autoride to standard shocks or how long do these autoride shocks last. Front shocks have sensors and a plug.
I was going to put standard ones at all 4 corners unless some one can tell me other wise.
I don't tow with it
I don't tow with it
