Well here is the review of the Window Racer.......
As I said in the other post
It is bulky 3"x3"x3" with no way to mount it.
I had to replace the ground strap crimp on ring terminal because the terminal is way to small to mount to a good ground with what is available under the dash.
When doing that I noticed that the manufacture uses non copper wire, not even copper coated.
Next is the breaker. As you can see the one in the car has the same size blades the Window Racer does not.
I am not sure if the breaker in my car is original but it fits in the fuse panel without issue
When you go to install it in the Window Racer it sits in lopsided due to the blades being equal length.
I will have to go to the parts store and pick up one that fits correctly into the Window Racer.
And finally here is a video.
I put tape on the window so it is easy to see it in action.
First run is without, second is the unit installed.
Keep an eye out for the crazy stray cat!!!!
