silverfox said:I have been looking for old topics but can't seem to find one
I have an olds cutlass and the pass window rattles like crazy I see the rattle kits on gbodyparts is this what I need to fix this and how hord is this to install
x2 this fixed mine but they still rattle alittle bit when they are all the way down.RITTER said:I would think if you replaced all the seals and felts that the rattle would go away :idea:
69hurstolds said:For 9.95 to do both doors, this is a pretty good deal. It's for older Camaro/Firebird, but the same material needed.
http://www.sandsclassics.com/cgi/displa ... SS-0001L-1
They'll work as it's only the fabric strips. Brackets may be different, but for this case, you are only looking for the strips, correct? If so, this should work. For G-bodys, GM sold the assembly which was the bracket with the fabric attached. One silver, one gold. Can't remember which color was for front and which for back. I think I only bought 2 of each though.silverfox said:69hurstolds said:For 9.95 to do both doors, this is a pretty good deal. It's for older Camaro/Firebird, but the same material needed.
These are showing for a Camaro are these the same for the Cutlass
