Window sweeps?
WanaBa442
WanaBa442
331
New England
Bought this set last year: window sweeps
Noted to be for "with special molding".
Pulled the old one off, the sweep part rotted off the chrome beaded assembly so there was a nice gap between the door and glass.
I pulled the new ones out of the pkg today, and found they have no chrome bead.
Installed one side, really doesn't look right.
anyone used these? Thinking I need to attempt to strip the old rubber and fuzzies off the old chrome beaded backer and sandwhich that between the new sweep and the door frame to complete the OEM look?
Any ideas?
565bbchevy
565bbchevy
7,442
Michigan
Sell what you have and buy ones with chrome.
Reactions: Drkuhar
69hurstolds
69hurstolds
3,879
There isn't anything really that fits 78-88 in outer window sweeps that I'm aware of. 81-88, sure, but I think you got the ones with the wide B85 molding that sits on the top of some Regal and Cutlass doors from 81-88 era.
Does it look like they should be stapled to something flat on the outer side and has no bead at all? Just wondering. If so, that's probably the wide molding style.
WanaBa442
WanaBa442
331
New England
Well, after carefully excising my cranium from my rectum, I found that they fit reasonably well. Don't ask.....
The lip that sits on the door ledge should be where the chrome bead would be is just black rubber. Almost the same shape.
Without seeing the wide molding I don't know if they would work there.
The originals have a solid steel (stainless?) backer that has the bright lip on top, and the sweep looks to be molded to it.
My replacements are nowhere near as sturdy and will probably get additional screws to hold them to the door without gaps.
They'll do for now...
69hurstolds
69hurstolds
3,879
That's strange. But if they fit well and will stop the window from rattling and prevent 40 gallons of water from entering the door, then great!
WanaBa442
WanaBa442
331
New England
Added 3 screws to the sweep backer.
Closed up the gaps and made it sit even.
Looks much better now, and seals up the huge gap that was there.
Cajun83HO
Cajun83HO
103
Louisiana
I just purchased a set of NOS outers and repop inners from Mike's Montes for my 83 HO.
Waiting for delivery.
Thread starter Similar threads Forum Replies Date
DROLDS84 Window Sweeps Oldsmobile Cutlass / 442 / Hurst/Olds 16
Hubb79 Window sweeps Interior 0
Ribbedroof MALIBU FREEBIE! - Central OK - Landau external qtr window hockey sticks G-Body Parts For Sale / Trade 0
P 4 door/wagon driver side rear outer window sweep Wanted 4
bazthespazz Rear window for 1984 El Camino Wanted 0
Kennyjoe28 NEED! 83-87 regal rear window hard top trim Wanted 9
J Window switch bezel General Discussion 1
RideOrDieRegal84 Power window failure Electrical / Ignition / Starting 12
P Window sticker help Chevrolet El Camino / GMC Caballero 10
M Rear Window Handle Wagons! 1
8 G-body door window belt molding G-Body Parts For Sale / Trade 0
CleanCutty86 Window stops Body / Trim / Paint / Glass 3
Dave_logan14 81 El Camino rear window (tinted) G-Body Parts For Sale / Trade 5
J Power window switch wiring Electrical / Ignition / Starting 2
blackbuck350 81 malibu wagon rear window weather seal General Discussion 19
SSpev Power Window motor Electrical / Ignition / Starting 3
Thelittlecutlassthatcould Broken rear window Body / Trim / Paint / Glass 4
69hurstolds CUTLASS Power Window wiring diagram adding relays to speed up the window motors How-To's / Knowledge Base 33
4 86 442 Rear Window Lower Trim Clip???????????? Body / Trim / Paint / Glass 6
yaahoos Drivers side power window n/w Interior 3
565bbchevy Jumping power window switch Electrical / Ignition / Starting 4
HAFROD Rear window interchange years Body / Trim / Paint / Glass 17
pontiacgp Power Window Switch General Discussion 14
85ss/85gn Rear side exterior window trim Wagons! 13
Grnmnstr Rear window, lower garnish molding clips General Discussion 19
Drkuhar Inner window weatherstrip mounting question Interior 4
CaliWagon83 REGAL Power Window Regulators - Same or different between coupe and wagons/sedans? Body / Trim / Paint / Glass 3
P Buicks & Coffee with a Window Racer Install w/ Before and After results Video General Discussion 0
D Setting window in weather striping on driver door is there anyone who does ajustments New Users 1
T 87 El Camino window adjust Body / Trim / Paint / Glass 0
GBody.co.uk Spring Loaded Power Window Regulator Refit Body / Trim / Paint / Glass 9
Tomeal El Camino quarter window seals Body / Trim / Paint / Glass 0
P Rear window to trunk piece General Discussion 7
1bad79 Gm window cranks Body / Trim / Paint / Glass 1
Similar threads
