Because someone must've took it off. The vertical B pillar next to the seat belt from 81 to 88 had a wide strip of "chrome" (actually anodized aluminum) on all G47 Oldses regardless of top options. The only difference is how much was cut off if the car didn't have T-tops. Bascially there were only two part numbered versions, a T-top and a non-T-top version. They were the same piece, but the non-T-top version got cut off at the top to allow it to fit inside the window opening, where the top of the T-top version went up and met the rear T-top channel bright trim. I think the rest of the G-bodies used them too, but some had black versions. Olds never used a black version from the factory. Lucky for you they make repros now. Some people think its cooler just to take them off as they do get impinged by road debris/thrown pebbles, etc., and look like dog crap after a while. Gbodyparts.com sells them. You can probably find them around the restoration websites. I haven't really searched.
Check it. Here's both versions still in the wrapper. Look at the top of the moldings carefully. The outer ones are for T-top, the inner ones are for non-T-top. Found on every 2-door Cutlass from 81-88. In a pinch, you could trim down a T-top piece of molding to work for a non-T-top car, but unfortunately you can't go the other way.
The top of the door trim was interesting. It was standard on Calais and Salon (85/86 442s only had it too) versions, but you had to add B85 RPO to the other cars to get it. I also think the 88 CSC had the wide molding standard as well, but I don't have any information about that. An interesting exception to that is the
Hurst/Olds models, as they were devoid of the ability to have B85, even though there is no mention of it in the dealer ordering information. I believe the reasoning for this was the body colored rear hood trim wouldn't match up well with that tiny little piece of "chrome" molding sitting on top of the rear of the fender. It's about an inch or so long and the factory plastic push retainers dry up and it will eventually fly off the car somewhere. Probably find it next to a lost
H/O spoiler wingtip somewhere. Here's a pic of those little boogers.
The 87 442 was based on the Supreme body, but the dealer ordering info showed the B85 as an option, and then says it's STD on W42. But looking at the W42 option, it states B85 is N.A. with W42. Guess what? It was N.A. in the real world. 87 442 didn't have the B85 moldings.
Here's a pair of B85 moldings. The rubber seal could have been purchased separately, but the way it mounts to the trim itself was just fugging weird. Not sure I'd go that route unless absolutely necessary. But sometimes it's necessary. Some Regals used these, too as they shared the same door shell with Olds. Which Regal packages? I dunno. It may have just been an option and/or included in packages like Olds.
