Window trim paint removal question
Livewild
26
10
Miami Fl
Hello, quick question. I bought a 80 Malibu and the trim was painted black. Is there any way I can remove the paint without ruining the original chrome. I’m worried paint stripper will remove the finish as well.
Thanks.
Longroof79
Rocket Powered Basset Hound
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
Thanks.
How well bonded is the black paint? Perhaps you can try to strip away some of the black paint to see what the trim looks like underneath. It could've been scuffed and primed with etching primer. I assume you're trying to revert back to the original chrome. Depending on how scuffed the chrome is, you may end up keeping the trim parts painted....or do what Donavan did to his chrome, doing a brushed stainless look, which I feel looks great and subtle in appearance.
Livewild
26
10
Miami Fl
Yeah, I’m trying to go back to the original. I was just worried that paint stripper would kill the original chrome finish. It looks like it’s just a layer of black sprayed over everything. From what I can tell there is no primer.
Longroof79
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
I could understand your concern about compromising the chrome. You can try a small area that's somewhat hidden or barely noticeable. Another thought would be to have the trim parts soda blasted. It would strip the paint without harming, or compromising the chrome finish. Then again, it would entail having to remove all the trim parts to be able to work on them reasonably. Either way, it might still require that you remove the trim.
Livewild
26
10
Miami Fl
I have no problem removing the trim so that’s not a concern to me. Im planning on painting the car. Im just hoping it’s not scuffed or sanded beyond repair underneath. Thank you for help!!!!
08Malibu
1,447
3,385
North Jersey
Thanks.
You can probably use oven cleaner to strip the trim. I used to use to strip anodizing from aluminum. I’m sure you’ll have to polish the trim back up anyway.
Rktpwrd
Builder of Cool Shjt
4,152
23,828
Calgary, Alberta, Canada
The trim is indeed anodized. Clear anodized, but anodized nonetheless. It sticks to the trim extremely well, oven cleaner will take it off, but expect more than one application to do so. The oven cleaner will not damage the finish underneath, but it will be more dull appearing than with the anodizing.
The trim on our cars is not chrome, in fact it’s not even stainless or aluminum like the older iron. It’s made out of white or “pot” metal, cheap, lightweight and easy to manufacture. It will polish up once the anodizing is stripped off, but don’t expect it to hold its lustre very long when exposed to the elements.
As for removing the black paint without disturbing or damaging the finish underneath, I don’t believe it’s going to be possible, depending on how well it is adhered of course. If it wasn’t scuffed before being painted, there’s a good possibility that it’s not stuck on all that well, and even a good blasting with a strong pressure washer might take it off.
You’re just going to have to experiment with it a little bit to find what works best for you.
Good luck.
Reactions: 4 users
Ribbedroof
4,861
6,888
Wellston, OK
Chances are it was rattle-canned. Costs nothing to try a little lacquer thinner on it to see if it will come off. Good quality thinner will strip spray paint immediately.
I prefer to start with the least-invasive method, and move up from there as required.
Livewild
26
10
Miami Fl
It was most definitely rattle canned on, I’ll start with my pressure washer, hopefully that removes most of it. After I’ll go with thinner, oven cleaner, then lastly stripper. If all this fails. What are my options to have it redone ? Could it all be removed with some sort of blaster (sand, bead, walnut,soda) then powder coated?
