Ok, its safe to say i know nothing about windsheild washer fluid, and i dont even know where a pump or something is, could somebody guide me in the right direction to get a pump from the junkyard and installin git in my car
if it's a stock set up then you'll find the pump in the cover on the wiper motor. There is a metal tab that holds it in place and you can change it without removing the wiper motor, it comes out from the bottom of the black cover. If you do take the wiper motor off just remove the two top bolts and slide the motor out of the rubber seat. The bottom bolt isn't that hard to remove but it's a b!tch to try to get it back in....
