How do I get to the Windshield wiper pump
Mines isn't getting any water when I push the button ? Can someone help me
Pictures would help also
what does with or without intermittent wipers mean ?Its the 2 wires on the back of wiper motor on firewall right beside hood hinge. 3 wires run the motor, 2 wires run washer pump, you'll see fluid hoses leading right to the pump diaphragm.
how do u get to the third bolt in the back to take it off ? And also how can I tell if it's even getting power to the washer pump ?Its the 2 wires on the back of wiper motor on firewall right beside hood hinge. 3 wires run the motor, 2 wires run washer pump, you'll see fluid hoses leading right to the pump diaphragm.
Keep the top 2 bolts in , its a 10 mil socket , use 1/4" drive an feel for it, its a pain in the arse.. Socket has to fit into a half circle sort of thing. Check with your finger first to locate it ! Undo it first then the top 2.
There is only a positive and a negative going to the pump, the pump runs off the wiper motor, so turn wipers on an with a power source put power to the 2 wires, if it cycles it will go click click . if it clicks an no fluid then its the diaphragm . 4 bolts on white plastic housing hold the diaphragm in place !
