Winshield wiper/washer ???
Doug Chahoy
2,564
2,661
Went to change my washer pump but NOBODY has the same one. I've bought 2 and looked at hundreds online. Mine has 3 pigtail connections, everything I've seen only has 2. Most also show an external wire between the wiper motor and the pump. Mine doesn't have that. I even started a thread in the parts wanted section if anyone has a good matching complete unit for sale. I can't post pics here, but I could to an email or text.
Frustrated as all hell, NOTHING this week has gone right .
Doug Chahoy
2,564
2,661
These parts companies SUCK!!!!! They show and describe a part then there's not one in the country anywhere. I have to send them my pump and motor for them to rebuild mine. The only good part is I know it will fit and hook up.
Doug Chahoy
2,564
2,661
I believe mine also has internal electric problems. When I bought the car the OO told me the washer pump wasn't working. Now I can understand why he didn't fix it.
20,391
Back in the 60's I think the GM trucks used a 3 prong washer pump. Have you tried a 2 prong pump to see if it works?
This is where things get complicated because it comes off the wiper circuitry. I got balled up in that on my 63 88, and had to seek professional help. :X3:
  • Optimistic
Doug Chahoy
2,564
2,661
Me needing professional help, no argument there. But if the rebuild doesn't work when installed, I will get that kind of P.H.
9,591
12,612
I mounted a small 12 volt washer pump directly to my factory reservoir down low where you can't really see it and keep the factory cap on with a dummy hose that doesn't connect to anything to keep the factory look.
This set up also eliminates the pulsing the factory pump has.
jatguit
114
4
Ok, so here is a picture (1st pic), that I have of a spare motor and washer pump. I circled the 3 pigtail connections. Is yours like this? This comes from a car with Pulse wipers and yes has wires that you can see Red and Black, but I believe they all do have that. Now, here is something that I experienced a long time ago. ACDelco was offering a different looking, but functional, wiper/washer assy, but you had to splice in or use an electrical adapter to your current wire system to make it work. It looked like the 2nd picture on here. That one had NO wires inbetween, but appears to be only 2 pigtails.
2nd picture
