here's an update, one day a few weeks ago the key security light came on when stating the Jeep after picking up a coffee. The engine died in a few seconds so I tried it again and it died again. So I started it with the remote and put the key in and it kept on running and no issues like that again. The check engine light came on again on another day when I remote started it. I left the light on and drove it a few hundred miles but the light would not go out. So the other day I checked the codes and these three came up
1685 - immobilizer/key problem
0443- gas cap
0141 - O2 problem....
so I removed the ground on the battery for a few minutes and after I put the ground cable back on the check engine light was off. I have driven the Jeep close to 300 miles since the codes were cleared and the check engine light is still off so I assume those codes were an anomaly. I guess the codes won't clear if I drive the Jeep 100 miles like it was suggested. The code for the O2 has shown up twice so far and that was when I used the remote to start the Jeep. I have not used the remote to start the Jeep since I cleared to codes to see if the O2 code would reappear which it hasn't so I'll be trying the remote start and see if that O2 code will show up. I don't know why starting with the remote would cause any codes to appear but it might just be a Jeep thing...
