Wire help
buick7332
350
589
N.E. Philadelphia area
That’s probab
so I can pretty much just eliminate everything that comes out of the passenger side?
Yes, it will come through the firewall behind the glove box at the top of the carpet. Unplug the computer, its behind the kick panel and remove the harness. There are 2 screws in the engine compartment that hold the harness to the firewall.
Lukeschwtz
16
10
Don't over think it and confuse yourself. Everything you need to made the engine work is the harness that is located under the power brake booster on the driver's side of the fire wall. It is very easy to swap a v-6 to a v-8 in a gbody.
