I'm just not happy with the routing of my harness. It's very tight behind my engine and firewall. Anyone have a solution that I'm not seeing?
Once I get my 2hr drive done I'll explain. To be continued...Injectedcutty hid his pretty well; maybe he'll play nice and share.
Under the booster is most hidden. I used the cruise control grommet hole for my DBW harness.
Thank you sir! It took me many years to change my way of thinking to get it to this point. When I was younger it didn't matter really, as long as everything worked, that's evident in this pic from when I was running a carbed 355...Those are goals right there ^^^^
One day I wish to have a clean engine bay like that
Man oh man. I guess I'm going to pull my dash out sooner than I expected 😌Ok, lemme give this a go here. In an effort to tuck and hide as much wiring as possible I did the following.
The factory harness block on the firewall was removed, hole welded closed and smoothed. The fuse block is mounted under the dash, with the main starter wiring entering the engine bay right behind the intake along with the engine harness.
The headlight wiring was routed through the driver side fender and protected, then travels between the inner and outer fender. I welded studs to the inner fender to mount insulated clamps holding the wires, then ground the heads down to make em disappear. The wiring appears into the core support, and is wrapped in braided loom. I did the same for the electric fan wiring which runs along the pass side fenders, and enter the cabin via a hole and grommet by the old antenna hole. Here are pics of that..... View attachment 158369 View attachment 158370
For my LS harness I went with a standalone unit that was custom built for me to keep the ECU under the dash. This dramatically cleans up the engine bay, and allowed me to drill one hold directly behind the intake. The harness enters the engine bay and splits to each side respectively according to the sensors, injectors, and such. I'm not gonna sugarcoat it, trying to tuck wiring is super time consuming, tedious, and hurts my hands, but the end results are so worth it. I still have some more to do over winter, but I'm pleased with the current state of progress. View attachment 158374 View attachment 158372 View attachment 158373
