Wrong thermostat??
My Camino
29
12
8
I just got the 5.3 lsx started in my el Camino.
I have a new three core copper rad with two electric fans. The thermostat is a 187 F.
My car heats up to about 187. One fan kicks in, then the other after a bit. Some times one kicks out. But they are almost always running. The car holds 190 steady but the fans never quit. The lower rad hose seems quite a bit cooler then the return line. Am I running two hot of a thermostat. Should I be changing to a 160F?
Note sure what’s going on.
When I filled the rad full of water. I filled the rad. And I added coolant in a plug I have on the water pump spacer. I left the steam
Port hose off of the rad till it was full trying to avoid an air lock.
Any suggestions?
UNGN
3,048
3,264
Southlake, TX
For a fuel injected 5.3L in a hot state a 160 degree thermostat will probably work fine... but the the real question is, what is making the fans come on?
Are they controlled by the LSX ECM or on-off thermo switches? Can't you just change the fan temps in the ECM? The second fan probably doesn't have to come on until 210 with a 190 degree thermostat. If it is set in the ECM to come on at 190, it will run forever with a 187 thermostat,
My Camino
29
12
8
They are controlled by the engine CPU. I will have the set points checked. I just assumed they would still have the factory setting. And I used the same temp rated thermostat that it came out with
My Camino
29
12
8
No one in my small town has a cpu that can read the temp and change set points. They can trigger them to turn on an off lol. But no programming.
So I changed to a 160 thermostat, and the fan cycles now as it should
Thx for the input fellas
