X pipe
dickeymoore
924
Atlanta,Georgia
I have a 1979 Chevy Malibu with small block Chevy 400 engine I will be installing Hedman headers part number 68606 Mid length headers is there a x pipe to hook up to these Hesders with a 3 inch to 2 1/2 inch pipe diameter also using a g force crossmember rcg-700?
lilbowtie
3,460
3,965
Canton Mi
Don't know your reasoning for wanting an X pipe but I got 0 gains from that set-up.
565bbchevy
9,609
12,663
Michigan
I put a Summit universal x-pipe on my Regal because it made it easier to go from the wide spread of the headers up front to the narrow factory Y-pipe that I tapped into
  • Informative
  • Useful
Local Hero
729
1,916
Northcoast, Cleveland, Ohio
My wagon came with a brand new exhaust system installed including an X pipe. It also has a G Force crossmember holding up the Turbo 400 trans.
I could tell the exhaust was the absolute last thing added to the car because it was in the way of EVERYTHING! It was a nightmare just trying to get the driveshaft out the two times I needed to drop the trans. I also didn't want to take the exhaust loose for fear of leaks afterward. Tough getting the starter out too.
It was all I could do to get the crossmember slid back far enough since there was no removing it, to get the trans down nearly sideways.
I don't care if an X pipe was worth 50 horsepower, I absolutely WON'T have another on any car let alone a daily driver like this car is. Once this system rots away it will be stock manifolds and true duals all the way back.
