Y crossover pipe?
pagrunt
9,159
15,327
Elderton, Pa
Will a 1978 Elco 350 Y crossover pipe fit bolt on a 1986 Elco 305?
Yes it will but you might have to swap the drivers side as most '78 350 cars used the earlier ('64-'77 A-body) manifold. Also you'll have to check the passenger side to see if the flange is for either a two or three stud manifold. If it's for the three stud then you'll need the '78 passenger side too. Later trucks also used the newer three stud manifolds like the two stud ones used on our cars.
elcotrk
Oct 8, 2021
51
9
8
Thx, good to know my 86 manifolds are 2 bolt and the 78 Y pipe is 2 bolt so it should fit. My manifolds have AIR emissions tubes, 78 doesn’t. Y pipe bolts to catalytic converter on 86, as I would think on the 78
  • Winner
