Since the R4 compressor is fanous for leaking/short lifespan, I have been considering going back to an A6 compressor. Anybody still using one?
So what is your reasoning for using an R4?Buy a good quality R-4. Flush entire system out(All components including hoses) Add correct amount and type of oil to each component(usually 10 ounces to whole system). Use a vacuum pump that boils water and pump as long as you can. On large systems i would go overnight. Add the correct amount of R-134A and you will get years of good service. PM me if any questions.
Lighter and more efficient.So what is your reasoning for using an R4?
I have all the bracketry for both systems.
Back when I was driving the previous generation of GM intermediates never really had an issue with an A6 compressor. Wish I could say the same for R4s, including some OE installations
For that reason I installed the Oldsmobile wide open throttle compressor cut out switch on the pedal of my Malibu.It's been my understanding that the key is don't Rev the R4 past 4500 RPM. I haven't personally experienced bad service out of an OE R4.
